06-13-2014 09:13 PM
Hi Everyone,
I'd like to know if there is a way to use IVI drivers to simulate a Keithley 6430, and also maybe a Keithley 2128. I don't have the device but I would like to make some tests, so simulating it would be very useful.
If it is possible? If yes how should I do it? Is there a tutorial?
Best Regards,
06-13-2014 09:36 PM
06-14-2014 01:40 AM
Hi Dennis,
Thanks for your answer.
I do already have downloaded them, and they show something in Max but the drivers for the Keithley are Visa Drivers, and I can add an IVI control on the block diagram but I dont know what to do with it, as IVI is not Visa right.
What is the next step?
Best Regards,
06-14-2014 03:21 AM
06-14-2014 02:13 PM
Hi Dennis,
Thanks for your answer,
I have downloaded the file from this link: http://www.keithley.com/base_download?dassetid=16504
As state on this webpage: http://www.keithley.com/products/dcac/sensitive/highresistance/?path=6430/Downloads#3, I have first downloaded and installed the
and installed then the IVI driver from the previous link it gave me acces to some configuration under MAX, but I don't see it, on the front panel, in VISA Control List I only see it in the IVI control List.
Also, on the Keithley configuration panel, installed with the I/O Layer, whenever I change the configuration of simulated to TRUE it gets back to False by itself.
I know I am lacking some knowledge in with IVI driver, Thanks a lot for you help,
Best Regards,
06-15-2014 07:53 AM
