The VISA driver library cannot be found (visa32.dll)
Hi!
I'm developing a Software that uses NationalInstruments.VisaNS and NationalInstruments.Common .net libraries. I have
installed already following packages:
- VisaSharedComponents32.msi (usb driver -> USB Test and Measurement Device (IVI) )
- NIVISAruntime.msi (install the visa32.dll and some other components)
- MStudioCommon.2005.msi (NationalInstruments.Common .net 2.0 library)
- MStudioVisa.2005.msi (NationalInstruments.VisaNS .net 2.0 library)
Now I got this error message: (visa32.dll is in C:\Windows\System32)
14:48:39 -> Init USB device 0x0123::0x0456 ... ERROR: System.DllNotFoundException: The VISA driver library cannot be found.  Either VISA is not installed, or VISA is improperly installed. ---> System.DllNotFoundException: Unable to load DLL 'Visa32.Dll': A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A)
   at NationalInstruments.VisaNS.Internal.VisaDll.OpenDefaultRM32(IntPtr& sesn)
   at NationalInstruments.VisaNS.Internal.VisaDll.OpenDefaultRM(IntPtr& sesn)
   at NationalInstruments.VisaNS.Internal.VisaDll.viOpenDefaultRM(VisaHandle& sesn)
   --- End of inner exception stack trace ---
   at NationalInstruments.VisaNS.ResourceManager.FindResources(String expression, Int32 resourceNameBufferSize)
   at NationalInstruments.VisaNS.ResourceManager.FindResources(String expression)
   at DutChanger.ChangerLogic.InitUsbDevice(String device)
14:48:39 -> System.Exception: Initialisation of device 0x0123::0x0456 failed!
   at DutChanger.MainProgram.Main(String[] args)
It seems he doesn't found the visa32.dll although this file is located in System32 folder!
Can someone help me please?
Thank you in advance!
Greets
(26,292 Views)
No one ?!
Thx
(26,259 Views)
I need a solution for this issue!
Greets
(26,252 Views)
have you got the correct version of VISA installed?
Regards
Ray Farmer
(26,238 Views)
Hi!
Sure. Last packages from NI site!
greets
(26,092 Views)
Hi!
I was able to solve the issue!
Solution: dont install parts of the installation, use the full setup package!
Setup package: http://joule.ni.com/nidu/cds/view/p/id/2914/lang/en (NI-VISA 5.1.2)
Greets
(26,087 Views)
For anyone who is interested to minimize the installation I found out which package was missing: VC2005MSMs_x86.msi
(you will find the folders in your extracted setup files in the Products directory)
The full list now:
VisaSharedComponents32.msi (Device driver)
NIVISAruntime.msi package: NI-VISA_Runtime
MStudioCommon.2005.msi package: MStudioCommon2005
MStudioVisa.2005.msi package: NI-VISA
VC2005MSMs_x86.msi package: VSMSM
Greets
(26,007 Views)
