06-02-2012 08:38 PM
Dennis, my one and only friend here!
You were correct, the intermediate cable was no good and a null modem adapter has made some progress. Now maybe I have a real question for you.
MAX is happy, and a visa test panel IDN query returns the scopes parameters. Also, under the driver finder winder, the TDS210 shows up.
When I run the VI, it sometimes passes the Initializer and sometimes hangs in the for loop. A continuous waveform is never recorded. The stop button or abort button will not stop and the only option is to disconnect the device.
Im using the Tektronix TDS 200 1000 2000 driver that claims usb/serial/GPIB connection.
06-04-2012 05:27 PM
Are you able to successfully run the Acquire Waveform VI? (for just getting a single waveform)
When the Acquire Continuous Waveform VI fails, does it give any error code or error message?
06-04-2012 05:36 PM
06-04-2012 06:53 PM
I have heard of a number of people who have had problems with the Prolific converter. It is not clear whether the problem is the device or the driver. I have not been able to get it to work at all on my Mac. The FTDI adapter seems to have fewer problems.
Lynn
06-04-2012 08:23 PM
Nathan, I will answer your questions and then some...
First, in MAX, sending the query "curve?" over and over returns the following responses in randomlike order,
0xBFFF0015 (VI_ERROR_TMO) Timeout expired before operation completed.
0xBFFF006C (VI_ERROR_ASRL_OVERRUN) An overrun error occurred during transfer. A character was not read from the hardware before the next character arrived.
0x3FFF0006 (VI_SUCCESS_MAX_CNT) The number of bytes transferred is equal to the requested input count. More data might be available.
I am running the single waveform VI as you suggested. The autosetup seems to crash, so I removed it. The fetch waveform subvi can run with this warning error code
1073676294
If I try more than once it will lock up at the visa read node inside the readsingle waveform VI, the program freezes and I can not abort (see attached). I also may get the blue screen of death and my computer crashes
Something tells me that data is getting stuck somewhere. I have tried to modify the VI's by inserting flush buffer nodes but no success.
