01-29-2016 01:40 AM - edited 01-29-2016 01:43 AM
Can you tell from which location you got this answer ?
Still I think there is a USB driver on your system that will work together with the Yokogawa USB driver.
01-31-2016 05:12 AM
Is it possible to try this on another computer ? I think you only need to install MAX and VISA (run-time)
02-01-2016 12:32 AM
The instruments should also being listed in the Windows Device Manager. Are they OK there ? If there is an error, the VISA layer can't wotk properly. There you also should be able to view the instruments USB ID in properties .
02-05-2016 03:14 AM
K C ha scritto:Is it possible to try this on another computer ? I think you only need to install MAX and VISA (run-time)
Sorry for the late reply.
I haven't tried another pc yet but in the meantime I've connected the 2 WTs using the RS232 interface and they can work simultaneously.
02-05-2016 04:42 AM
OK. Not a nice workaround but it is a solution. In your case I can imagine that that is fine for now.
I assume you have WT without GPIB and/or Ethernet. That would be much faster.
Still I am curious what the result is with another computer if that is possible.
Kees
02-05-2016 05:12 AM
K C ha scritto:OK. Not a nice workaround but it is a solution. In your case I can imagine that that is fine for now.
Kees
Yes, Acquisition with RS232 is fine for me.
I've just connected (USB) the two WTs on another PC and I have the same problem. They cannot work simultaneously.
02-05-2016 06:01 AM
That is strange. Now I am pretty sure that one of the instruments is wrong. But I don't think you want to send it in for repair just for this.
Kees
