connect Tektronix DPO 2024, Error-1074000000 occurred
Hi:
I connect a Tektronix DPO 2024 With PC via USB,
use sample code:"Tektronix DPO MSO 2000 4000 Series Acquire Digital Voltmeter Example.vi",
But "Error -1074000000 occurred at Tektronix DPO MSO 2000 4000 Series.lvlib:Error Query.vi" occured.
somebody know how fix it.
thanks.
(4,520 Views)
DVM is an invalid command.  Find where you are sending that command and correct it.  I recommend giving the programming manual a good read.
GCentral
(4,515 Views)
