keithely 2420 using the latest 24XX driver
I'm working on a Labview program (please see attached) which can source current and measure the coresponding voltage by using keithely 2420 for battery test.
I used the latest 24XX driver for keithely instruments.
The only issue is the"read (single point) VI ". I use it to read the voltage, but it is keeping producing erro code (-1073807339). I couldn't figure it why.
Could someone please  help me to figure ir out?
Thanks!
(4,482 Views)
This may help troubleshoot your problem: http://digital.ni.com/public.nsf/allkb/874B379E24C0A0D686256FCF007A6EA0?OpenDocument
Best of luck,
SFuller
(4,459 Views)
Thanks.
I figureed it out. The VI "enable output" should be put just before the "read VI".
(4,444 Views)
Even better put only the read vi in the while.
greetings from the Netherlands
(4,435 Views)
