polling gpib/enet unit over tcp/ip using java
I understand that there is a linux driver for the gpib/enet product. Since I assume this device is polled over a tcp/ip connection, do I need to do this in C, ot can I establish a socket connection using java ? If so, what is the driver for ? is it just to assign an ip address and other setup functions ?
John Adams
(3,207 Views)
Hi John,
You do not need to do this in C. In fact you can do it in just about any language. The librarys are exported to a shared object, so as long as your language can make calls to a .so, you are good to go. I am positive that java has this capability.
Hope this helps out! If you need the driver, it is available at www.ni.com/linux.
Best Regards,
Aaron K.
Application Engineer
(3,207 Views)
