06-03-2011 10:08 AM
How to tell what 'enet' devices are present using LabView??
All devices are listed with ‘DAQmx System. DevNames’ wether or not they are present in the system.
I am using the DAQmx Reset and looking for an error to determine if a device is present or not, … this works, but waiting for the error time out can take several minutes. ... see the attached jpg. There must be a better way?
Thank You
06-03-2011 12:43 PM
Use the system configuration API on the measurements palatte
06-03-2011 02:49 PM
Thank you for the reply. I have tried this from the expample: 'show all hardware.vi'.. 'isPresent' shows the 'enet 9213' as being present (-1) wether or not it is connected??
Bummer....
