LabVIEW Automotive Ethernet
Raw Ethernet Frame Decode and Encode Example
Newer versions of Wireshark install Npcap which has been confirmed to work with this example on Windows 10. I would recommend reinstalling Wireshark to the latest version.
Regarding jumbo frames, there isn't a frame size limitation in the LabVIEW project. Check your network adapter settings in Device Manager to see if jumbo frames are enabled there. If so, there may be a limitation by the hardware you are using.
Message 11 of 12
(1,917 Views)
Hi, quick question: what I'd like to do is to make a Custom Device (For a RT Linux Target) for VeriStand using this so I can read ethernet traffic in a PXIe 8840 Quad-core. Do you think this is gonna be posible?
Also, is it possible to run this on a RT Linux Target "without" a host PC?
Message 12 of 12
(1,723 Views)
