LabVIEW Communications System Design Suite
Program Crash - SISO TDD OFDM on NI USRP RIO
Anyone encounter similar program?
When i run the Example "SISO TDD OFDM on NI USRP RIO" (can transmit & received video streaming),
after i stop the program, always get Warning Message, then, when i click continue, LV will crash and LV will close
LV Comm will stop and need to run again
I didn't have problem with other example
My PC and USRP:
PC:- Intel Core i5-4430@3.00GHz,8GB RAM, Windows 8.0
USRP:- NI USRP-2943R
Warning:
Warning 1073383043 occurred at niUsrpRio Config v1
Host.lvlib_Check Data Clock Rate and Bandwidth.gvi
Possible reason(s):
You are using a bitfile configured for a data clock that is slower than the rate
required for the bandwidth of this device. This may result in aliasing in your
signal.
I attached the screenshot for more details:
Message 1 of 1
(2,696 Views)
