The Block Diagram Cleanup utility was a great improvement when it came in LV 8.6. But it is far from perfect. In large or medium sized programs, structures tends to be very large, many times more than needed. Here is one example which is a part of a main program. If I use Cleanup on the hole program, the result is for this part:
But if I mark the two inner case structures and press the Cleanup button, the result is:
Then I select the “Exclude from Diagram Cleanup.” for the two inner case structures, mark the outer structure and press the Cleanup button again. The result is much more compact:
Why cannot LabVEW do this automatically? If it starts with the inner structures and works outward, the result well be much better than today.
