07-18-2016 08:48 AM
Can anybody please tell me how to use analog port and distinguish values of different analog pins using that port?
07-18-2016 11:01 AM
I suggest you use LINX.. The example Analog read N Channels.VI is included in the installation software. LIKFA is no longer supported by National Instruments.
hrh212
07-18-2016 01:07 PM
Is there any delay between reading multiple channels simultaneously using LINX?
07-18-2016 05:36 PM
Arduio UNO boards have only one ADC, so yes there will be a de;ay between readings. The conversion rate for Arduiuno Uno boards is approximately 10,000 samples per second.
hrh212
