07-11-2022 03:20 AM
thx its work, wonderful
10-09-2022 02:19 AM
your fix instructions is too easy and it works well,
Thank you so much.
02-10-2023 12:10 PM
What is the solution when using Labview LINX though since LIFA is being replaced with LINX?
Error 5003 occurs even when the port is not being occupied in the IDE. One reason I noticed was that aborting the VI vs. stopping causes this error, but there must be other reasons too. Not entirely sure what is the reason. Anybody figure that one out with using LINX firmware?
12-22-2023 01:59 PM
i am sorry, i did not understood, can you please which value you set with '0' ?
01-27-2024 04:25 AM
Thank you very much,
It helped me a lot now, not sure how in 2023, this error still exists
03-13-2024 06:25 AM
You are a life saver!
Thank you very much
06-19-2024 08:33 AM
Thank you, this solves it. I had the same issue!
08-09-2024 11:34 AM
This is perfect!! Thank you very much Thomas Plummer!!
10-28-2024 08:43 AM
