12-17-2015 09:55 AM
i have a Problem with Arduino and Labview i have every Time the error 5003. I hope someone can help me.
12-17-2015 04:31 PM
Hi,5003 means that Labview does not see your Arduino.Have you installed LINX on the arduino yet?Install LINX and make sure you have a close serial at the end of your code. Make sure it gets to run even if you have errors in between start and end.Barddya
To: barddya <barddya@yahoo.com>
Sent: Thursday, December 17, 2015 7:56 AM
Subject: - Arduino Labview error 5003
NI Community |
Arduino Labview error 5003 created by falkii in LabVIEW Interface for Arduino - View the full discussionHello, i have a Problem with Arduino and Labview i have every Time the error 5003. I hope someone can help me. Reply to this message by replying to this email -or- go to the message on Community Start a new discussion in LabVIEW Interface for Arduino by email or at Community |
12-18-2015 01:25 AM
I programm with Lifa, i have Tested Linx too but i have no idea how i can programm the dht22 with Linx.
12-19-2015 05:20 PM
Neither LIFA nor LINX has native support for that sensor but LINX, in general, will be better to use. LINX has a much better way of integrating custom functions so that you can add sensors like the DHTXX sensors using existing Arduino libraries.
Have you searched the LINX forums? I know people have worked on getting at least one of the DHTXX sensors working.
01-13-2016 06:27 AM
Yes i have searched the linx Forums i have found something about the dht22 but it does not work
01-28-2016 08:09 AM
Hallo i have news it works with dht22 but when i add digital write pins the 5003 error comes back hope someone can help me
