05-10-2013 11:22 AM
As an update: I just went through the above process on a WIN7 computer with LV 2011SP1. After finding out about the .pde to .ino file change it worked like a charm. Thanks.
06-28-2013 10:48 AM
do we have seprate lifa base file for arduino uno and arduino mega?
if yes then please attach the link please.
06-28-2013 12:39 PM
The Uno and the Mega use the same firmware. There is code in it to account for the differences automatically.
06-29-2013 12:55 AM
i'm attaching link for downloading LVIFA Base.pde for LabVIEW 2012
https://drive.google.com/folderview?id=0B583mduU6WwaSEtKMlVySGJGb0E&usp=sharing
06-29-2013 02:31 AM
The firmware comes with LIFA and should be obtained via the JKI Package Manager.
07-18-2013 03:33 AM
how to dump lifa_base.pde to arduino i am getting error
07-18-2013 03:42 AM
i am getting error of synclv is not declared in this scopeplz find error n send me original pde file
07-18-2013 04:37 PM
The correct files come with LIFA and are in the Firmware folder. If you are getting errors about things not being in scope that usually means that the Arduino IDE is not opening all the files. Make sure that you first start the Arduino IDE and then select File > Open and select LIFA_Base.ino. It will then open all files in that folder. You should be able to compile it then.
10-22-2013 11:02 PM
thanks you very much from .....
01-03-2014 07:41 AM
Good morning I have a problem now that I can not do my Arduino DUE now communicate with their poles above him and managed to install the program on the Arduino board. Now I can only communication from RX to TX Transmit is not working, can anyone help me?
