Many developers have the primary ethernet port of their development computer reserved for the corporate intranet/internet access.
Unfortunately, MAX and other tools like RT System Deployment Utility expect the targets to be connected to the same primary port for initial configuration, because they do not allow the specification of a local IP on which to exchange the UDP configuration packets.
Being able to select the ethernet port on which the RT system is connected, e.g. through a ring control populated with all available NICs and their local IPs, would facilitate devolopment enormously in such constellations, because the developer would not need to switch cables and IP configurations every time he needs to reconfigure the RT system.
Sebastian
Hi Everyone,
With the new NI Linux Real-Time based controllers released at NIWeek this year we include a USB Device port, which I think addresses the pain described in this post, allowing you debug/modify the target without messing with your existing Ethernet infrastructure. For more information you can read here: Ethernet over USB Connection for Simplified Target Configuration, Debugging, and Maintenance
Best Regards,
Deborah Y.
LabVIEW Real-Time Product Manager
