If you have a deployed RT system running the scan engine you may have IOV channels with scaling that was configured and deployed from the project.
What happens when you need to change a scaling factor after the system has been deployed? You would need the development tools to do this.
Since the smarts for this is already built into the LV IDE why not put the same code into MAX for remote viewing and modification of IOV properties.
