LabVIEW Real-Time Idea Exchange
Vinal_G
Missing "Stall Data Flow.vim" VI in RT side
Status: New
Hello LabVIEW Enthusiast,
NI has introduced malleable VI function since LabVIEW 2017. It is a great function to have in advanced LabVIEW application development.
But "Stall Data Flow.vim" function is missing in Real-Time Target OS from timing function palette since 2017.
It is not like you can not use malleable VI in RT side, I have copied same VI from desktop VI to RT VI. It works fine without any error or broken arrow.
NI should include this types of VIs in RT package by default.
RT has Type Specification Structure too, which creates question for me on this missing VI.
If you have any reason(s) to share on this why it is not included on RT side, Please share your thoughts.
Vinal Gandhi
Vinal Gandhi, CLA
1 Comment
Petru_Tarabuta
This idea can be marked as completed.
Stall Data Flow.vim now appears in the Programming >> Timing palette when loaded from an RT target.
Setup used for testing: cRIO-9045 using LabVIEW 2024 Q3 64-bit.
