Currently, if you have hardware in a LabVIEW project (e.g. a cRIO controller, cRIO chassis, or R-Series PXI card), the only way that you can change this to another product is by adding a new one to the project and deleting the old one. It would be nice to be able to use a configuration window to change the model number of a piece of hardware to a different, but similar one. For example, if you have a 9072 in the project but wanted to change it to a 9073. Another example would be the ability to change, via menus, a PXI 7813R to a 7854R. Of course the user would have to update any code written to account for changes due to the new hardware. This is especially convenient when you are simulating and configuring test systems but aren't quite sure exactly what hardware you need. Currently, for each new piece of hardware (similar or not) you have to create a new device and copy all of the IO, VIs, libraries, etc. under the new device in the project.
Kareem W.
Web Product Manager
