For the use of a variator that generates his own clock and distributes it on EtherCAT, I need to make the RT loop synchronous with clock posted on EtherCAT by the variator.
So would require the scan engine parameter is in receipt of the EtherCAT clock.
This function is imperative on Labview-RT to be compatible with ability to manage EtherCAT variators ( Beckhoff).
