LabVIEW provides an interactive front panel when running an RT application in the LabVIEW development environment. However, once you deploy this front panel is no longer available. I think it would be helpful to make the front panel look differently or somehow give a visual warning/indication that this is a debug feature and will not be available at deployment. (This could be something as simple as a watermark, similar to the evaluation watermark that LV employs). Many new users get confused and run into problems by using lots of front panel controls/indicators and then finding out later these are not applicable at deployment.
