It would be good to enhance access security to also include program-control of cRIO's. As it is now you can set user access for a cRIO in a project by opening the Real-Time CompactRIO properties and set Allow/Deny access by IP. However, this only limits access to deploying settings and eventual RT applications on the cRIO. You can still control the cRIO (e.g. set outputs and, as in my case, control servo motor drives connected to the cRIO) from a LabVIEW application on any PC on the LAN.
This added access control could eventually be set up in MAX.
