07-10-2013 09:14 AM
Hi
I have a 1433 frame grabber that I need to interface to a Dalsa Pantera 22M04. Is there an existing camera file for this sensor? I also need to modify some of the camera settings via the serial port. I tried using the clsercon.exe program, but am unable to locate documentation on how it should be used.
Thanks in advance,
A
07-11-2013
05:21 PM
- last edited on
03-12-2024
09:01 AM
by
Content Cleaner
It does not appear that we have an existing camera file for that model of camera. However you may be able to create your own using the NI Camera File Generator. You can specify the framegrabber you want to use then use the UI to configure the file for that particular sensor. The applications help has excellent documentation on how to navigate through the environment. You should also be able to add serial commands to the camera file, however you would need to know the commands from the cameras documentation or manufacturer.
