9236 enable shunt cal property crashes crio OS with scan engine
I would like to inform users of the 9236 Quarter Bridge Strain Gauge Module of a bug. The Real-Time team is aware of this issue and I have been working with an app engineer on it for about a week and he has confirmed my findings. He says the problem is most likely a driver issue or scan engine issue and they are investigating it.
There is a bug that completely crashes the cRIO operating system with the 9236 module. Currently when a cRIO device is loaded with LV2009 SP1 or LV2010 and using scan engine interface, attempting to write the "shunt cal enable" property of a 9236 module completely crashes the VxWorks OS. If you try to access the property again, the crio crashes and enters an error state where the crio has rebooted twice without being told to. The LED indicator blinks four times to indicate this.
I have tested this with a few different hardware combinations with both the crio-9014 and crio-9012 controllers, combined with either the 8-channel 9104 back plane or the 4-channel 9102 back plane with the same results. The app engineer was able to duplicate this issue as well.
To duplicate the bug:
Load a crio device with 2009 SP1 or LV2010 and configure the device for scan engine. Locate the 9236 module in the project explorer and drag and drop it into a VI to create the IO variable. Right click the output terminal of the IO Variable and go to create > property > enable shunt calibration  on a channel. Once the property is dropped, right click on it and do change to write so that you can write a boolean to the variable. It doesn't matter if you write a true or false to the property, the results are the same. Hit run, watch it crash. When it reboots, hit run again. The crio is now in a state that can only be recovered by physically resetting the device.
I love the crio stuff and I use it every day because it is very reliable and robust. This kind of thing is rare, which is why I am reporting it to the community as well as NI as it is a pretty big bug that took me a while to narrow down.
[will work for kudos]
Message 1 of 1
(2,756 Views)
