9791 gateway not connecting with windows7
I want to connect my WSN gateway with my PC directly. So I used cross cable to connect and also set my IP. I have Windows7 as my os. But, after connecting it, it is showing no network access, and a yellow triangle on the network icon. And the gateway is also not detected at the MAX. I have Labview 10. But, if I do the same process in XP, then all the things come smoother and MAX is detecting the gateway and I become able to do the communication. What is the problem? Please help.
(2,481 Views)
have you tried to add it manually? You can do this by right clicking Remote systems -> Create new... -> Remote device (not on the local subnet).
Also, is the NI-WSN software properly installed? You can check this under My System -> Software.
Daniel
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(2,479 Views)
Thanks for the reply. I am trying to do it. Then coming soon to state the result.
(2,471 Views)
Accepted by topic author LSG
It is working....my WSN software was not properly installed.After reinstalling, it is working..thanks a lot....
(2,453 Views)
