04-07-2015 08:23 AM
I am developing a LabVIEW vi to control two EPOS2 70/10 and brushed DC motors and I use absolute SSI encoder.
1). I would like to know If there are any inbuilt VI's to control the software position limit in the EPOS controller. If not, how to access the position limit to avoid damaging my test object.
04-08-2015 03:57 AM - last edited on 03-12-2024 07:29 PM by Content Cleaner
Hi pushpakp,
what LabVIEW Version are you using?
Are you using the Softmotion Module:
https://www.ni.com/en/support/downloads/software-products/download.labview-softmotion-module.html
Or the EPOS2 Drivers:
Best wishes
Tenshinhan
04-08-2015 04:06 AM
I use LabVIEW version 2011 and also I use the EPOS2 drivers.
04-08-2015 04:24 AM
these are Third-Party Drivers and for them you will get support via http://support.maxonmotor.com.
You should contact Maxonmotor for this.
04-08-2015 04:52 AM
to answer your "2nd question" , you have two options :
1) Connect both EPOS2's serial interface to your pc = 2 cables
2) Use the CAN Gateway over the EPOS2
check this thread Parrallelism-EPOS
How it's properly cinfigured for industrial use: I think with a CAN Master interface.
Note: The Vi's from Maxon work fine, I use them on LV2014.
