02-15-2018 03:23 PM
We use EPICS clients/servers on cRIO platforms. I would like to access the timestamp of when the EPICS variable was updated. The timestamp is visible in the Distributed System Manager and we can access it from other consoles outside of the LV environment. Getting the timestamp outside of LV is an "option" when reading the VAL or other fields.
Any suggestions?
Solved! Go to Solution.
02-15-2018 03:31 PM
Discovered it myself,,,, right click on the variable on the block diagram,,, show timestamp
02-15-2018 03:33 PM
