02-19-2014 02:25 AM
02-19-2014 07:55 AM
02-19-2014 08:14 AM
Are you reading the values using VISA Read? You could easily just take the readings and build up an array and then save that data to a file.
02-19-2014 09:49 AM
02-19-2014 10:16 AM
02-19-2014 11:06 AM
02-19-2014 11:10 AM
What version are you using? I see a driver for back to LabVIEW 8.2.1.
Agilent 532XX Series Counter/Timer
02-19-2014 11:12 AM
02-19-2014 11:20 AM
02-19-2014 11:27 AM - edited 02-19-2014 11:28 AM
I highly recommend upgrading to a newer version.
Here's a very quick example of how to perform a querry for an instrument. You have to write the querry command and then read the response. You may have to add a delay in there to allow the instrument to respond.
