Analysis of XY Graph data
Remember the en masse operations I talked about?
Well, use that to your advantage.
Simply take your array of angles, as read from the device, and subtract the "zero" point from the whole array.
Example:  If your array of angles is [ 28.1, 29.3, 30.2, 30.9, 31.8. 32.7 ]
And you decide your "zero" point is 29.3, then subtract that from the array, which gives you another array:
[ -1.2, 0.0, 0.9, 1.6, 2.5, 3.4 ]
Now you have the angles in "normalized" form, relative to the start of the pad.
If you're careful, you don't need to zero the stage before a reading.  The only "gotcha" is where 359 wraps around to 0.
If your hardware will rotate continuously, then your angle will wrap around, and you need to detect the sudden change (359-->0) and have an "adder" term of 360 that you add from then on.
That is so that the angle will go from 350 - 440 or something, and your arithmetic will still work.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 21 of 23
(412 Views)
Yeah, that's basically the idea I tripped to right after I hit "Post". I don't have to worry about >360 degree rotation at the moment, or at all, I don't think. All of these parts (that I know of, anyways) are not full circles, they all have an open bore.
Thanks a lot for your help, I really appreciate it. For some reason arrays and array operations really bake my noodle. No idea why, but these types of problems end up taking me much longer than they should. I'll let you know how this turns out.
Message 22 of 23
(408 Views)
It's not the part I was referring to but the stage.
In my mind it would be better to avoid the "zeroing" operation, and tell the user to plop the part down anywhere.
But that might happen to span the 359--> 0 mark on the stage.
You can handle it if you're looking for it: just have the ADDER variable, initially zero, and always add it to the angles.
Go thru the angles and if you see a transition from large (350+) to small (<10) then add 360 to the ADDER and keep going.
That removes the sudden step from your angle array and your arithmetic still works. Your ANGLE array might go from 350 to 550, but you don't care - you're going to normalize it to zero anyway.
Steve Bird
Culverson.com
LinkedIn
Message 23 of 23
(401 Views)
