08-19-2010 04:22 PM
I'm putting my application on a protected partition so INI there will not be writeable. I need to put an INI on a writeable dirve. How do I specify this in Application Builder? How does this carry over to an Install build? Can the installer prompt for a INI location or do I need to hard code it in?
C: protected flash drive partition
😧 unprotected partition (location of INI file)
Thanx
08-23-2010 11:38 AM
You have the ability to do either way. The easiest way is to include all files you need in the installer. You can go to the "Destinations" selection within the Installer Builder. There you can add absolute paths and then use the source files selection to determine where certain files are going to be installed. This will allow for you to have multiple files span multiple volumes. Hope that helps!
