04-25-2011 05:34 PM
I have found that including the NI Application Web Server 1.1 in the installed software list of a cRIO will cause a hard crash and hang.
I am including the MAX report of the software that I am running. Is this some known conflict?
04-27-2011 08:07 AM
Hi sachsm,
What cRIO model are you using and when are you seeing the crash? Is it during the install process, right after install or when you are trying to run your program?
<Brian A | Applications Engineering | National Instruments>
04-27-2011 08:15 AM
I was recently notified that this problem has been reproduced by NI AE. I will post an update when I get more information...
I am running on a cRIO 9076 + 9144 etherCAT. The crash occurs after the rtstartup.exe is running, around 30 seconds into it and then
a sudden hang with no console errors or error log output. The system restarts after another 30s and the cycle repeats.
04-28-2011 11:56 AM
Glad to hear you were notified by an AE that the problem has been reproduced. If possible, please post what you hear from them as I'm sure other users with the same problem will want to hear the solution.
Thanks!
