At my work place using labview 7.0, i need database toolkit for lv v 7.0
hi,
    hi to everybody... i need a database toolkit for my application in LABVIEW V 7.0.
and any one tell to how to program in database toolkit....
thank you in advance... i hope i'll ge right solution for my post.... Smiley Indifferent
N. Srinivasan
Message 1 of 11
(3,620 Views)
You need to contact your local NI office/rep.
- Partha ( CLD until Oct 2024 🙂 )
Message 2 of 11
(3,608 Views)
Since 7.0 is long obsolete, I would recomend that you look at LabSQL. It uses ADO technology just like the NI toolkit.
Message 3 of 11
(3,601 Views)
hi dennis..
 if i use labsql i have to know about the command set for the SQL...
is any other way to use database tool in labview v7.0... and i too using labview 8.6 in this version separete database toolkit is present but at my work place they using only labview 7.0...
help me for the further process.... ??
N. Srinivasan
Message 4 of 11
(3,594 Views)
Yes, you would have to know something about SQL but that is not difficult. Otherwise, look for someone selling a used copy of the old toolkit or convince your company to finally upgrade.
Message 5 of 11
(3,590 Views)
learning the basics of SQL (SELECT, INSERT etc) shouldn't take more than a few hours if you consult some good tutorials, and its a good skill to have under your belt.
Don't be put off by this, LabSQL does include some simple examples which should get you started.
Message 6 of 11
(3,574 Views)
hi dennis and nrp,
  thank you for response.... i'll study SQL commands... if u dont mistake me can u send any example program regarding to this application... and some tutorials too...
thank you in advance....
N. Srinivasan
Message 7 of 11
(3,564 Views)
hi dennis,
   i need your help... can tell me how to use labsql.. now i know the command set for sql...  if u guide me how to do the program in labsql means it'll be more more more helpfuuullll for me.....
thank you in advance.... for very reply...!!!!!!!!!!!
N. Srinivasan
Message 8 of 11
(3,535 Views)
hi to all,
 can any to tell me how to use labsql in labview 7.0.... if possible explain in step by step....
N. Srinivasan
Message 9 of 11
(3,534 Views)
hi,
   i need your help.. guide me to do program in LABSQL... im using LABVIEW 7.0..i dont want to purchase database toolkit i plan to use labsql... i was download the labsql zip file... but i dont know to go further... i know the command set for the sql.... im doing the program to test the "PCB" it  will have 32 i/o pins each pin have to send different type of signal.. so that output signal from the pin should be saved n the database with the help of labsql...it should have 32 column's...
     After the data's are saved in the database... i'll go for the next step is to check the other PCB with fault in it.. now i'll send the 32 signal to 32 i/o pins and the output signals should be compare with previous saved data in the database... if its match means status of the pin will true or else fals.. At last i'll generate the report for the Pcb...
Kindly help me... waiting for your reply ....
N. Srinivasan
Message 10 of 11
(3,524 Views)
