Average Value Scope
Hello Everyone
I have dso-x 3014a agilent scope.I use ethernet cable .Normally ı get normal value from my scope with attachment vi . I set scope to "acquisition mode averaging" and adjust #Avgs  8,16,32,64.., when  ı push run button, scope says NO DATA FOR OPERATİONS. How can ı take average signal data from scope ?
What should ı do take averaging signal data from scope ?
Thank you for your time and attentionSmiley Happy
Message 1 of 46
(4,987 Views)
@ELEPRO wrote:
Hello Everyone
Shouldn't you be reading the manual for the scope instead of constantly asking here these types of questions?
Message 2 of 46
(4,968 Views)
Message 3 of 46
(4,961 Views)
There should also be a programming manual that you should find.
GCentral
Message 4 of 46
(4,954 Views)
Sorry  it is wrong . Is 3000_series_prog_guide  right sir ?
From here http://www.keysight.com/en/pd-1947865-pn-DSOX3014A/oscilloscope-100-mhz-4-channels?cc=TR&lc=eng
Message 5 of 46
(4,947 Views)
Message 6 of 46
(4,927 Views)
Yes, that looks like the programmer's guide.  That manual tells you what commands you are supposed to send to do whatever you need.  It is often helpful to keep this manual around to better understand the drivers you are using.
Are you able to manually capture an averaged waveform?  The averaging is typically only used for periodic signals in an attempt to clear up some of the noise.
GCentral
Message 7 of 46
(4,918 Views)
Sir ı made new iv in attachment . I capture an averaged waveform. But ı have a problem. Problem ı just capture #Averages 2,4,8,16,32. When ı try more averages 64,128.. I got attacment warning.
How can ı handle this problem sir ? What should ı do ?Smiley Happy
Message 8 of 46
(4,905 Views)
Sounds like you just are not allowing the scope to capture enough waveforms to average.  It takes time.  Depending on your waveform, a lot of time.
GCentral
Message 9 of 46
(4,894 Views)
Did you even try to do it manually? That would have given you a big clue as to what you should be setting the timeout to.
Message 10 of 46
(4,886 Views)
