Beginner - Adding and removing itens from a tree/table.
I would like to know if it is possible to add and remove itens from table, like a tree.
If you see the image attached, you could note what I want to do. For instance, I would like to check items in the table below (many itens can be checked) and so, when I click the button Add, the itens go to the first table.
If I check items, in the first table, and click the Remove button, the items checked go to the second table.
I get the items tree from a XML file.
Thank you in advance.
Gustavo
(2,441 Views)
Forgot to say that you should be free to give me another interface ideia.
Thank you again
(2,439 Views)
