Bertan Series 225 HV vi
Does anyone have a driver for a Bertan Series 225 HV (communicating through GPIB)?  The one found here:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9635659CE034080020E748...
does not work that well.
Kevin
(2,949 Views)
atomless wrote:
The one found here:
What exactly didn't worked? Are you getting any error message? Please post where you stuck up. The rest of the things we will take care to solve your problem. Give more details and collect more help form here.
(2,943 Views)
Hi Mathan:
I have solved my problem (for now).  Is there any danger in taking the code from
and controlling more than one Bertan 225 at the same time?
Kevin
(2,931 Views)
Absolultely not. You are free to do anything. BTW, you said you solved the problem(for now). What is the problem you faced and how you managed to solve it? This information will help others in the future.
Mathan
(2,928 Views)
You should be able to control multiple power supplies.
Are you using serial, GPIB or USB to do so?
You would simply require seperate control references for each of the supplies.  The drivers should be the same (although I am not familiar with this particular power supply).
R
(2,927 Views)
