Best/Most Efficient Way to Determine What Changed in Array of Cluster
This is a (dirty) way to get only the index of the changed cluster element:
Not sure why that's useful, but 😁 it sure would be efficient, esp. for large arrays...
Message 11 of 16
(332 Views)
Interesting  loop, a while loop that self identifies as a for loop.
Message 12 of 16
(316 Views)
Or rather a for loop that identifies as a while loop.
I really love that method actually! I think it can be programmed faster than the while loop.
CLA
Message 13 of 16
(313 Views)
More importantly: the result is less and cleaner code.
Consider that a while loop will always executes at least once... So you're always stuck with either a case to skip the action, or a redundant action.
Message 14 of 16
(302 Views)
More importantly, the FOR loop will also stop when it runs out of elements. A while loop requires more condition here
Message 15 of 16
(280 Views)
Have used this one before. Is less janky and weird as it first feels.
You can also get the name of the control which has changed via property node, just make sure to uncheck the "Block UI thread while handling Events" or whatever that terrible default option of the Event Structure is called.....
Message 16 of 16
(248 Views)
