Best way to get amount of memory available?
What is the best option currently to get the amount of memory available (programatically)??  I'm using LV 2011 & 2014.
Back in 2013, I got a VI from "jtagg" here, and that's what I've been using since then, but I'm not sure it's reporting what I need. I guess I don't understand exactly WHAT it's reporting. It's attached.
Jtagg, are you out there?
(4,200 Views)
Jova,
What type of memory are you interested in monitoring?
The following links might be helpful.
Profiling VI Execution Time and Memory Usage: http://zone.ni.com/reference/en-XX/help/371361L-01/lvhowto/profiling_vis/
Memory Usage Page (VI Properties Dialog Box): http://zone.ni.com/reference/en-XX/help/371361L-01/lvdialog/memory_usage_properties/
How Do I Use LabVIEW to Find Out My Computer's System
Information: http://digital.ni.com/public.nsf/allkb/B2DA61D0AE0A548686256D0C00666A9B
This forum post might also be a good reference depending on what you need to monitor:
Programmatically Monitoring Windows memory
https://forums.ni.com/t5/LabVIEW/programmatically-monitoring-Windows-memory/td-p/1394970
Will M.
Applications Engineer
(4,153 Views)
Will, thanks for your suggestions.
I need to programmatically monitor total memory used by our LV application (or conversely, app memory still available), over long periods of use (it runs 24/7 at our customers), as a way to watch for memory leaks.
Your first two links are not for programmatic monitoring, and the second two are quite old, from Win XP days. I'm wondering what's recommended for Windows 7 32- or 64-bit and LV 2014.
(4,131 Views)
If you are monitoring application usage long term I recommend using Performance Monitor:
http://www.7tutorials.com/basics-about-working-performance-monitor
It obviously doesn't break it down by VI memory usage but does log lots of data on various processes and other PC statistics.
(4,122 Views)
I found that in my search for an answer.  It doesn't work.
(3,198 Views)
Hi Jim,
you should explain the words "it" and "doesn't work" more precisely...
(3,185 Views)
If you have access to the System Configuration (found it under Real Time, but I don't think you need RT to use it), then you can get the memory figures directly.
GCentral
(3,166 Views)
