08-17-2018 09:16 AM
Ok, this is entirely my own fault, but I just want to ask if there is anything I can do.
I have a state machine which had a fairly large block diagram, 1 display in height, and 2-3 in width. I can't find the "Tools > Profiles > VI metrics" to check how many pixels it is.
I selected a small section of my code this morning and clicked "Clean up selection".
This has extended my whole block diagram well outside the maximum 32000 pixel limit.
I (very stupidly) only realised this after I had saved.
Now, my whole block diagram won't render properly, or display half the items.There are wires going everywhere into 'nothing', and, it's very slow and unresponsive.
Other than restarting from my latest backup (which isn't very recent, again, my own fault), are there any things I can do to bring the block diagram back within the limits, so at least it's useable, and I can try to sort it out.
Thanks for any help,
Graham
08-17-2018 09:22 AM - edited 08-17-2018 09:23 AM
Graham
Unfortunately, I don't know how to "go back in time" on something like this, other than physically doing it by reverting to an earlier version. My personal take on the cleanup tool is that "If the cleanup tool consistently makes your code look better, you should probably rethink your approach to LabVIEW coding." I think this is applicable here. 😞
ctrl + s is so comforting and so easy to do. I understand how regrettable pressing that combination of keys can be. 😞
08-17-2018 09:54 AM
@billko...Graham
Quoting This Old Tony, "Time travel is dangerous."
Did you try a ctrl-z ?
If have not gone too far it may be able to recover.
it does sometimes work with the BD clean-up.
Ben
08-17-2018 09:56 AM - edited 08-17-2018 09:56 AM
I think ctrl + z gets taken off the table the moment you save the VI, even if it is still open and in memory - a BIG complaint of mine!
08-17-2018 10:13 AM
It just worked for me (LV 2017).
Ben
08-17-2018 10:23 AM
You can try the Ctrl-Alt-click and drag to shrink the diagram. It might pull in the "stuff" that got caught in the nether.
Also, plug for using source code control, it's kinda hard to get your head around it initially but it's sure a lifesaver on times like this.
08-17-2018 10:24 AM
Ben
I just tried it in LV 2015 and it seemed to work here, too. I thought I saw it in LV 2014 - but I could be misremembering things, too.
08-17-2018 10:25 AM
GREAT IDEA!
08-17-2018 10:52 AM
"Undo after save" got introduced in LabVIEW 2011 according to this idea.
(There are still plenty of things that seem to clear the undo buffer on occasion)
08-17-2018 11:16 AM
NO, this is NOT your fault, but apparently a bug or poor exception handling in the cleanup code itself. The cleanup too should be aware of its boundaries and enforce never exceeding the range limits. What LabVIEW version was that?
(Yes, the cleanup tool is buggy and incomplete. I rarely use it (never on my code, occasionally of messy code found in the forum :D). For example often the entire cleaned up code ends up outside the visible diagram area. How hard would it be to re-center?? 🐵
The limit is actually twice that, because coordinates are also allowed to be negative i.e. the full I16 range.
