Build_AB Error 13 occurred at Invoke Node
I've migrated from LabVIEW 2018 to 2022.  My application runs okay from source but will not build.
I've tried all the suggestions from here: LUDICROUS ways to Fix Broken LabVIEW Code with Darren Nattinger | GDevConNA 2022
Other posts about Error 13 suggest isolating different parts of the code to narrow down the problem VIs.
Please advise on other ideas.
error message:
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error 13 occurred at Invoke Node in AB_Engine_Write_Linker_Wrapper.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: Failed to load dynamic library because of missing external symbols or dependencies, or because of an invalid file format.
Shareable board exclusively owned.
Method Name: Linker:Write Info To File
(157 Views)
Have you tried a mass compile?
(156 Views)
yes, I followed all the suggestions in the YouTube video, mass compile is included.
(127 Views)
