Built Exectuable: Some systems (win7) close the app directly
I have an executable; it runs fine on most systems, but on some the front panel pops up when loaded, and the app closes within a second (also closing the front panel).
All the systems are win 7 64 bit and I cannot see what the difference is. My guess would be some security setting or something, does anybody have a suggestion?
(2,089 Views)
Hey,
    I know there have been a lot of complaints with running and particularly installing executables in Windows 7. Usually the issue has to do with the UAC settings. If you right click on the executable there might be the option to click unblock. If that doesn't work then I would try momentarily disabling the UAC to see if that's what's causing the problem. Obviously, you don't want to leave it off but that might identify the problem.
--Ryan
(2,073 Views)
