04-19-2010 05:40 AM
Hello:
I use a cin in my program,bu it works unstable,when the data comes to the cin then usually the labview crashed with out any hint. But some times the data can go through the cin and the cin can give the right resoult. When i copy the cin to another new vi,and give the same input and output,then it works mostly right,and some times crash.
But I need the other part of the program to process data, I do not know why it crashes so often and gives no hint ,i am really puzzled. wish some one can give a help , Thanks !
04-19-2010 06:18 AM
04-19-2010 11:14 AM
Hi ,Thanks for you help
here is the vi
if you need the data then i will post it out
04-19-2010 08:41 PM
hello ,here is the data
hope to get further help
04-19-2010 09:25 PM
I am sorry , I give a wrong data.
The original data is so large, about 100M
