CRIO 9073 Question
I think this image shows the issue.  I am using a network shared variable.  I send the command to set DISC_OUT::LIN OUT::VALUE to false.
The command executes, it can find DISC_OUT, but there does not seem to be anything under DISC_OUT, so it does not fine LIN OUT so it returns the Label Not Found as the Command Response.
Any thoughts on what may be going on?
Message 11 of 16
(202 Views)
OK, I see where the Labview VI is writing the label names and I can minpulate it manually.  The program reads the Label names from an XML file, and then writes them to the CRIO to initialize it.  I believe the issue is with the reading of the XML file, specifically, sending the expression for parsing the XML.  I am trying to understand what @SystemName means in the below expression.  Does it mean the PC Name?
Message 12 of 16
(194 Views)
Hi 5060,
The image in your message shows text that I would expect in a TestStand sequence: where does those text come from?
(The "@" char can be used in TestStand to indicate filepath data when using a string variable.)
Message 13 of 16
(190 Views)
IDKNT!
Learning every day
"Should be" isn't "Is" -Jay
Message 14 of 16
(180 Views)
Hi Jay,
I use the "@" this way:
Otherwise TestStand requires you to use double backslashes in filepaths, the @ allows to use single backslashes...
Message 15 of 16
(156 Views)
Thanks for all of the replies.  I was able to get my issue resolved.  Final problem was that the XML query was looking at the wrong configuration file.  Definitely learned a lot, thank you!
Message 16 of 16
(147 Views)
