10-20-2013 03:39 AM
Hello Everyone
I've created a PID controlled hydraulic application and I controlled the position by using Sine generator with the help of
CRIO 9074 and NI 9263.I worked the code on Realtime side. My freq is about between 0.67 to 1.5Hz. I used Fs=1000 s=1000 for
1hz. It works very well. But now I have a new problem I have to solve. I have calculated the position of cylinder in 1ms time resulation (or
2ms-3ms).How can I apply the position of cylinder with the help of excel file or any other file format(If I learn
the way of control. I can get the position from excel) . How can I use the data below as a position signal for PID.
for example
(1HZ-10MM)
1ms 0,1mm
2ms 0,4mm
3ms 0,87mm
1000ms 10mm
10-21-2013 03:13 AM
10-21-2013 02:09 PM
Hi GerdW,
Thank you for your idea. But I m looking for answer the position control with the help of PID controller. I did position control with sinus generator as my set point data. But now I want to use user defined position data as set point data instead of sinus generator.
10-21-2013 03:41 PM
Hi Sea1
I am not sure that I understand your issue or question; if you have a list of values in Excel with the parameters that you want to use for you PID then as GerdW recommended you can create and read the file to find a reference or pointer to select the parameters you want to use.
But if the excel data has some sort of parameter instead of reading a file it might be easier to calculate the values.
Could you provide us with more information or a more detailed explanation of what you want to do?
Regards
Esteban R.
