Can I pass a string value to a double numeric indicator?
I am doing a sequence of tests and saving each tests datas. When I bypass one of the tests, I need the string value 'BP' to get saved ( in the double numeric indicator ) for that particular test. Is there any possible way to do that?
Message 1 of 8
(3,972 Views)
When I have had to do this before I have placed a string control over the top of the numeric control, same size & shape, and made it invisible. When you bypass that test, just set the string to visible.
Message 2 of 8
(3,962 Views)
Accepted by topic author Rashme_SR
Maybe just use 'NaN' instead of 'BP'. You can store NaN in the numeric indicator.
Message 3 of 8
(3,958 Views)
Or change the numeric indicator to a string.
Message 4 of 8
(3,942 Views)
The numeric indicator works like a "Format into String" function with a hardwired numeric input.
So it really is a string indicator in the end.
You can use the "Format String" property node to modify how the numeric is displayed.
(Also available in Display Format ... --> Advanced Edit Mode.)
I don't think you can avoid displaying the numeric value, but you can add text.
So you could, for example, display: "0  BP".
Format string normal = "%#.2f";
Format string adding "  BP" text  = "%#.2f  BP";
Some of the suggestions by others on this thread might be easier to manage and give a better result.
(You have to swap Format Strings around and still have the numeric displayed.)
*Note however, that this technique can be used to do interesting things like add Units to your numeric indicator.*
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 5 of 8
(3,924 Views)
Here is an old discussion about the possibilities. Pretty flexible.
Message 6 of 8
(2,647 Views)
What am I missing here? Why did the 5 year old thread get resurrected?
Message 7 of 8
(2,616 Views)
Hard to tell, but it showed as new and unread here. Maybe it got bumped by a spam posts that got deleted soon after ... 😉
Message 8 of 8
(2,608 Views)
