Can Labview do auto cut and wire new VI that come between other 2 VIs?
The question is very simple.
I want that if i insert new VI between two other connected VI, then Labview will cut the wires between the two VIs, and will wire First VI to New VI input and the New VI ouput to Second VI input.
tnx,
HaD
Message Edited by HaD on 09-04-2007 09:39 AM
(2,402 Views)
To a limited extent yes.
Right-click on the wire and choose "insert" and then choose the objec to insert.
This will only handle one wire.
prior to LV 8.X this often wired the wrong terminals but since then its pretty good.
Ben
(2,396 Views)
It works pretty good, unless you want to insert a property node..
Ton
My LabVIEW Ideas
(2,384 Views)
