Can't Unbundle By Name slider
Hey,
I'm trying to use a slider control with two sliders. The Unbundle By Name does not seem to work correctly. Is this expected behavior, or has it already been fixed in 8.5?
Error: "Some items in the cluster input to this Bundle/Unbundle By Name function are either unnamed or have the same name as other items."
I'm using LabVIEW 8.2 on WinXP.
Message Edited by LabViewGuruWannabe on 11-20-2007 08:44 PM
Message 1 of 15
(5,139 Views)
I see the same behavior in LV 8.5
Message 2 of 15
(5,133 Views)
After giving the label for slider digital displays  in customize mode the unbundle by name will work.
-Kumar.B
Message 3 of 15
(5,128 Views)
Well, the sliders don't have names. I don't really see the need. How should they be called?
If you want to name them, cast them to a cluster with randomly named elements as follows. 🙂
Message Edited by altenbach on 11-20-2007 07:45 PM
Message 4 of 15
(5,125 Views)
Ok, so its expected behavior. I thought perhaps Slider 1, Slider 2, etc would be default. I see its the same thing with Gauges and XY Graphs. No worries then, I'll just add the extra step.
B-)
Message 5 of 15
(5,120 Views)
Don't get me wrong, it might be useful to give them automatic hierarchical names for convenience. Not a bad idea.
For example if the slide is called "Slide A", the sliders could be called "Slide A.slider1", "Slide A.slider2", etc.
There is always the product suggestion center . 🙂
Message 6 of 15
(5,116 Views)
I also think automatic naming similar to "Slider1" and "Slider2" would be a good idea.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 7 of 15
(5,090 Views)
This is not true!!!!!!!
Message 8 of 15
(4,297 Views)
Which is not true?
Message 9 of 15
(4,294 Views)
Sorry....
Kumar B. said: "After giving the label for slider digital displays  in customize mode the unbundle by name will work."
But I think this is not true!!!
If it is please show me how to do it
Thank you!
Message 10 of 15
(4,290 Views)
