Can't build installer with DAQmx 9.6.1 - troubles with locate of media path
When I go to build an installer that needs DAQmx 9.6.1, the installer requests the media path.  I don't have (can't locate) a DVD for DAQmx 9.6.1.  I downloaded the drivers but that download is not accepted.  It seems that I need the original disc.  Is that the case?  Do I need to get a physical disc in order to build this installer?
(2,824 Views)
Accepted by topic author skryger
You should not need to original disk for the drivers to be valid. Try installing the lastes version off of our website at ni.com/drivers and retry your installer. Sometimes the order of installation of LabVIEW and drivers matters a lot. In general you want to have the drivers be insalled after any upgrades or updates to the software that is using them.
Daniel G.
Semiconductor & Wireless
(2,806 Views)
Yes, that solved the problem.  Thanks.
(2,799 Views)
Glad that worked out for you!
Daniel G.
(2,786 Views)
