Can't import CAD model (.wrl file) into Robotics Simulation builder
Dear LabVIEW Users,
Actually i am facing a problem with importing CAD assembly file from SoidWorks into Robotics Simulation Builder, honestly i have followed the  exact same steps in the link Below, as well as i have found that some else stumbled in the same issue, regardless that i have followed the solution that they provided in the forums, but i didn't work with my .WRL files.
In other word  the Robotics Simulator couldn't accept my .WRL file that i generate using my SolidWorks, But i have download other WRL CAD from the internet and it worked.
Apparently the problem is with my SolidWorks files but i couldn't solve my problem.
Please check the link below for the forums that i followed their solutions:
https://forums.ni.com/t5/LabVIEW/Can-t-import-CAD-model-into-Robotics-Simulation-Model-Builder/m-p/2...
Ni Website:
http://www.ni.com/white-paper/14133/en/
Looking forward for your kindly help.
Thanks.
Dali,
(2,550 Views)
Hi!
Are you setting any other property on SolidWorks?
It seems weird that you could upload another WRL CAD, both have the same properties?
Did you check compatibility version?
(2,510 Views)
thanks for your response,
But may you clarify what do you mean by compatibility  ? i mean in which term ? version ? like SolidWorks 2017 and LabVIEW 2017 ?
(2,504 Views)
Yes, so, both are 2017 version?
Is there any other property set up in the file?
What is the main difference between the file that you can open and the one you don't?
(2,491 Views)
