Can't show LIN message from Master in Lin bus - vxlapi
Hi everyone,
I would like to describe the implementation process when using vxlapi and hope to receive comments from everyone.
I use vxlapi to retrieve Lin messages on Lin bus.
My environment has Master real. I simulate LIN Slave. Receiving Lin message from Master in the below description is that I can display Lin message from Master on Lin bus using vxlapi.
I setLinSlave according to LDF schedule and received LIN message from Master when I SetLinSlave for Unconditional frame. However, after I setLinSlave for the Diagnostic frame with the Classic check sum, I no longer receive LIN messages from the Master. I used Logic analyzer to check the signal and saw a LIN message from the Master using Logic 2.4.14 software.
I look forward to your questions and replies!
Thank you!
(247 Views)
Thank you for everyone read my topic!
After research https://cdn.vector.com/cms/content/products/XL_Driver_Library/Docs/XL_Driver_Library_Manual_EN.pdf
I not update xlLinSetDLC before Active Channel so I don't get any LIN message from Master with some data length.
I hope help someone have same issue!
(198 Views)
