06-15-2009 12:57 PM
06-17-2009 07:47 AM - edited 06-17-2009 07:49 AM
Hi peter,
Could you post a screenshot of the behavior you are seeing with the square and sine wave output? Also, how are you creating and outputting your signals? It sounds like you are using the Express VIs so I attached a quick piece of code that shows how to do this using the Create Analog Signal vi and the DAQ Assistant vi. I was able to output a square and sine wave over 20Hz with no signal decay on the 6251.
06-04-2010 02:21 PM
